Private messages taking over 40 minutes to be delivered
mr_a500
11 Mar 2013, 20:26
Is there something wrong with Deskthority private messages at the moment? Some messages are now taking over 40 minutes to be delivered. My last message has been stuck in Outbox for 43 minutes (...and counting).
(this severely hinders urgent conversations)
rodtang
11 Mar 2013, 20:34
They are in the outbox until they are opened by the person you're sending it to.
mr_a500
11 Mar 2013, 20:38
rodtang wrote:They are in the outbox until they are opened by the person you're sending it to.
That's odd. If so, then they've changed the meaning of "outbox" as I know it. Are you sure?
ne0phyte
Toast.
11 Mar 2013, 20:43
Yes just like rodtang said.
When you write a PM it is in your Outbox until the person logs in and opens the message. It then disappears from your Outbox and is moved to Sent.
Soarer
11 Mar 2013, 20:44
It's true. I've got one still in my outbox from 17 Jul 2012 :(
dirge
11 Mar 2013, 20:44
much like outlook mate, you're lucky I've got one to sixty from july!
mr_a500
11 Mar 2013, 20:48
ne0phyte wrote:Yes just like rodtang said.
Weird. Of course, it's a handy feature to know that someone read a message that was sent, but I would have thought it would be an indicator on the message in the Sent folder. Outbox is usually for messages that haven't been sent yet.
OK then, this thread can be closed.
xbb
11 Mar 2013, 20:54
dirge wrote:much like outlook mate, you're lucky I've got one to sixty from july!
pff I have one to 7bit_r4 from january 2012
Return to “Deskthority talk”
