Which I ask is the best ergonomic keyboard from most low price to most expensive?
Thank Before
looks like fundondy wrote:i never had RSI (at least not so severe that i went to a doctor to got it diagnosed)
i use a logitech m570 with a ducky dk1087xm (green "alps") - i just wanted to try out thumb trackballs after my mouse broke (i had a logitech marble before the mouse).
i like it though it took me about a week to get used to it properly (using games to train accuracy and speed)
and yeah, utron was the name! it's really expensive though :s
i researched a little (about ergonomic stuff) because i actually wanted special peripherals which apparently aren't available anywhere or stupid expensive :/
don't like Data Hand i prefer uTron with dvorak versionMuirium wrote:The best:
They cost SIZEABLE $BANK but put you straight in a science fiction movie!
And the Topre:
yes I want to try ergo keyboard, where do you think most goodMuirium wrote:Ergo keyboards are one of those things where you really have to try it.
The DataHand looks awesome to me, and I'd love to play with one for a while. But who knows? Maybe I'd hate it!
I soreness pain in the forearm and shoulder in left sideFindecanor wrote:If your soreness is in your upper arm and shoulder, then I suggest that you first check your posture and see if there is something that you can do about that. Make sure that you vary your posture during the day also.
I also changed to using vertical mice because of soreness in my right wrist.
I want to try ergo keyboard maybe ergo dox or gold touch,gold touch is rubber dome i thik mechanicdavkol wrote:If you have issues with forearms and shoulder, check your posture first.
- MS Natural Keyboard Elite or Dell/LiteOn/Silitek SK-6000 (about $20) — both are decent RD-over-membrane (Maxi Switch on the SK-6000 feels a bit lighter) keyboards with fixed "3D" split layout (works great in case of tennis elbows)
- Goldtouch Adjustable Keyboard (about $100) — very light rubber dome, solid, compact, supports tenting
- TypeMatrix 2030 (about $100) — compact matrix layout, my favorite scissor switches, Dvorak&Colemak hardware support
- ErgoDox and key64 — DIY, split, matrix, fully mechanical, fully programmable (and open source!)
- Kinesis Advantage or possibly some Maltron — split, matrix, programmable, suitable for DIY
Goltouch quite interesting,how rubber dome?hoggy wrote:Have you seen your doctor?
Consider rest breaks, posture (as noted above), text expansion software (texter is a good start). Just changing your keyboard is unlikely to fix everything quickly.
Goldtouch is indeed rubberdome - but it's still worth a try. Form factor is pretty good, and it's really quiet (not that you asked about noise).
I'll suggesting skipping the typematrix.
Kinesis advantage is a great board - get one. Well worth the price.
Do you use your left arm for the mouse?
i also doubt,maybe to typematrix 2020 more cheapFindecanor wrote:Beware though that there is an older version of the Goldtouch that has harder keys. It has no column of nav keys on the rightmost side.
looks unique,I'm less likesdondy wrote:http://deskthority.net/workshop-f7/my-d ... t2534.html here is also a collection of some layouts (though he opts for a more regular looking design later).
