Echoing Spacebar?
Cerr
- Main keyboard: CM Stom Quickfire Rapid
- Main mouse: Razer Deathadder
- Favorite switch: Blue
I recently purchased A CM Storm Quickfire Rapid which happens to be my first mechanical keyboard, and I couldn't be happier. Yesterday I noticed my spacebar made a "twang" sound like someone is tapping an aluminum can. The keyboard has costar stabilizers and I have not lubricated it since I purchased it a week ago. If anyone can help I will be extremely grateful!
Have you taken the space bar off? Stabs can be pretty tricky, and sometimes just taking them out and putting them back in again will do the trick.
Otherwise it sounds like lube is the answer. Just don't overdo it.
