- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
Contact:
22 Nov 2013, 01:54
Please suggest nominees for the Best keyboard switch in 2013. You have to give a short motivation for each suggestion.
Current suggestions (this list is frequently updated):
- Cherry MX Lock
- Nixdorf "Soft Touch" Black
- Clicky Univac magnetic switches
- Honeywell Micro Switch
- Matias Quiet switch
- Cherry MX Black
- Cherry MX Brown
- IBM beam spring
- Alps Plate Spring
- Cherry MX Ergo Clear
- Cherry MX Clear
- Topre switch
- IBM buckling spring
- Cherry MX Green
- Matias Click switch
rindorbrot
- DT Pro Member: 0029
22 Nov 2013, 02:36
The only non-momentary switch in the Cherry MX lineup:
Cherry MX Lock
photekq
- Cherry Picker
Contact:
22 Nov 2013, 02:37
The Nixdorf "Soft Touch" Black without a doubt in my mind, as they are the perfect linear MX switch. They are perfectly smooth without lubricant, and allow a large amount of customisation like the rest of the MX line.
22 Nov 2013, 02:46
The mad clicky
Univac that HaaTa discovered this year:
HaaTa
- Master Kiibohd Hunter
- Main mouse: CST L-TracX
- DT Pro Member: 0006
Contact:
22 Nov 2013, 03:44
Oh, once I get a couple of projects out of the way, I'm planning on assembling a team to reproduce the Univac magnetic switches
- Favorite switch: MX Lock
- DT Pro Member: 0001
Julle
- Main keyboard: Wooting Two HE
- Main mouse: CST L-trac
- Favorite switch: Lekker Hall effect
22 Nov 2013, 13:45
I nominate the Matias Quiet Pro switch. It takes some serious balls to make a mechanical keyboard with anything else than Cherry switches these days.
CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
Contact:
22 Nov 2013, 14:05
good point Julle - Matias Quiet Pro.
Jmneuv
- Main keyboard: Phantomized QFR
- Main mouse: LX8 (mod)
- Favorite switch: 68g
22 Nov 2013, 14:09
photekq wrote:The Nixdorf "Soft Touch" Black
Can you elaborate, please? Never heard of that switch.
photekq
- Cherry Picker
Contact:
22 Nov 2013, 16:18
Jmneuv wrote:photekq wrote:The Nixdorf "Soft Touch" Black
These babies :
The original Cherry clear switch top.
PERFECTLY smooth without any modding - seriously, there is absolutely no scratchiness whatsoever.
Photo from ascaii
22 Nov 2013, 17:11
The classic vintage black. How did they go wrong!
- The Tiproman
- DT Pro Member: 0010
22 Nov 2013, 17:13
I'd like to nominate the Cherry MX black switch.
I hold it for the best switch ever made.
Simple, reliable, smooth and steady.
It guides your fingers on their way down and gently escorts them on their way up.
The perfect touch. Exactly what a professional typist needs
Edit:
Ekaros
- Main keyboard: FILCO MAJESTOUCH 105 MX Brown SW/FI
- Main mouse: Razer
- Favorite switch: MX Clear
22 Nov 2013, 17:18
kbdfr wrote:I'd like to nominate the Cherry MX black switch.
Edit:
Heretic, MX Brown is the correct way!
I suggest a pre-poll for picking up one MX switch... Or group them to one...
Halvar
- DT Pro Member: 0051
22 Nov 2013, 17:22
IBM beam spring. Now usable again.
22 Nov 2013, 17:28
Quit showing off you, Mr. Beam Spring debutante!
I'll agree as soon as I have one too, of course. The one I've tried in a museum was magnificent.
Compgeke
- Main keyboard: IBM Model M 1391401
- Main mouse: Coolermaster Recon
- DT Pro Member: 0040
22 Nov 2013, 18:31
I'm a bit odd in that I actually quite like the Alps Plate Spring switch that's used in the PS/2 P70. My only complaint is the PS/2 P70 has a raised keyboard without plate mounted switches, making for a very flexible keyboard.
Game Theory
- Mr. Despair
- Main keyboard: Majestouch Convertible 2 or Beam Spring 5251
- Main mouse: Logitech G900
- Favorite switch: MX Blue in terms of MX
- DT Pro Member: 0008
22 Nov 2013, 20:53
Clicky Univac magnetic switches sound so nice!
mr_a500
22 Nov 2013, 21:43
That UNIVAC disturbs me... because now I have to find one.
I thought my keyboard quest was over with my beam spring, but now HaaTa has found not one, but two keyboards I must search for: the other being the ALPS magnetic reed keyboard. If there was a separate category for "Best clicky switch" and "Best linear", HaaTa could take both prizes with those two keyboards.
Dubsgalore
- Main keyboard: ESA-3000-HASRO
- Main mouse: Deathadder 2013
- Favorite switch: MX Blacks
22 Nov 2013, 22:32
Vintage Blacks are my favorite from experience
photekq wrote:The Nixdorf "Soft Touch" Black without a doubt in my mind, as they are the perfect linear MX switch. They are perfectly smooth without lubricant, and allow a large amount of customisation like the rest of the MX line.
How I wish i could try these..
TheSoulhunter
- Main keyboard: KBC Poker / HHKB
- Main mouse: G9 / Deathadder BE
- Favorite switch: 65g Clears
23 Nov 2013, 09:12
Ergo Clears, because... it's my favorite!
Also because all these custom springs (62g, 65g, 67g...) became available -> Less sticky Ergo Clears
23 Nov 2013, 10:57
HaaTa wrote:Oh, once I get a couple of projects out of the way, I'm planning on
For some reason I can't get this song out of my head.
There's going to be welding, helicopters and costumes, right? Looking forward to it!
- Wild Duck
Contact:
23 Nov 2013, 14:42
Alternatively, if that doesn't work out, MacGyver will reproduce the Univac magnetic switches with nothing more than duck tape, fridge magnets, a rope, and spit.
mr_a500
23 Nov 2013, 14:44
As long as there's a helicopter, I'm in. There also has to be a red Ferrari and an estate in Hawaii... oh wait a minute - that's Magnum P. I.
23 Nov 2013, 14:48
Note to TV execs: get back on your helicopters, take a good line of Beverley Hills high tea, and do what your 80s forefathers did! Those shows, those cuckoo, instantaneously classic shows.
Belfong
- Main keyboard: HHKB Pro 2
- Main mouse: Apple Magic Trackpad
- Favorite switch: Topre!
23 Nov 2013, 15:01
I think we gotta put MX Clears. Made even more popular by Code keyboard until it was out of stock WW and everyone is still hunting for one.
- DT Pro Member: 0011
23 Nov 2013, 17:57
Belfong wrote:I think we gotta put MX Clears.
I second this. Was going to nominate if you hadn't beaten me to it.
Ekaros
- Main mouse: Razer
23 Nov 2013, 18:46
Do we have time to do something different with this category?
This is horribly wide category always, any good options to narrow it down?
23 Nov 2013, 18:50
Pitting old vs. new (let alone home made, as in several other categories) makes for a crazy vote. But that's what the first round is for, I guess. I'll be voting for the ancient novelty of Univac switches on this one (and Hall effects and beam springs if we get multiple votes) but for new stuff in other some categories. Just depends on the field.
Ekaros
- Main mouse: Razer
23 Nov 2013, 19:30
Cherry MX could alone have the options for sufficient poll, throw in ALPs for good measure and we have same amount of canditates than a few other categories combined...
THESE ARE NO SUGGESTIONS
Cherry MX:
Black
Blue
Brown
Clear
Green
Grey
Red
White
And lock...
ALPS:
More crazy ;D
23 Nov 2013, 19:53
A little digging in the archive, and I present for reference:
Best keyboard switch 2011: Cherry MX Brown.
Best keyboard switch 2012: Cherry MX Ergo Clear.
Can the tyranny of MX be put to an end before Cherry wins the hat trick? Can spring bucklers and rubber cuppers put aside their differences to unite against continued dominion? Can the archaeologists settle on some bloody thing? Can 002 ever find a hat that doesn't split open at the crown? The truth, gentleman, will out!
