like M15
More Complete
http://blog.fsck.com/2013/12/better-and ... oards.html
thanks muriMuirium wrote:The images are indeed broken. You need to put the direct url to the .jpg file inside the [img] tags. Flickr makes this difficult sometimes.
you cut own the plate,symmetric board?jesse wrote:Thanks!Muirium wrote:And they were worth it. I've never seen prettier ergo keyboards! Nicely done.
I've been having a lot of fun designing them
I did not enjoy typing on the symmetric stagger board.Muirium wrote:How do you find the symmetrical stagger approach, versus full on ergo designs? I'm less adventurous a maker than you and I'm thinking about what I can do inside a more traditionally sized rectangular frame.
Thanks!hoggy wrote:Impressed! Great presentation, but great ideas too.
Me too! I'm a little sad I under-ordered on the 1.5x modifiers and the 2x blanks, but I'm making do.matt3o wrote:I like those brown caps
Thanks! It works in software and I didn't know enough to know it wouldn't work for hardware.webwit wrote:Great stuff, I really like how you got closer to your ideal by doing all those iterations, weighing what works and not etc.
You can try split symmetrical stagger board with V style,hand remain straightMuirium wrote:How do you find the symmetrical stagger approach, versus full on ergo designs? I'm less adventurous a maker than you and I'm thinking about what I can do inside a more traditionally sized rectangular frame.
i see you has one but not split,can you post here, if it split?jesse wrote:ماء, I have one of thoseAnd it's based on a lot of the same research I started with.
Did you photoshop that image? There's something weird going on between the hand plates and the shadows.
What about the lonely key which would be under the palm? When I'm not typing I like to "rest" my palm... Wouldn't that key trigger?jesse wrote:What I did today:
Only made one catastrophic error when designing the PCB
Nope. Even resting your palm, the inner edge of your hand is raised just a bit. I also rest my palms. And I never accidentally trigger the palm key. (It's a shift to a new layer with things like cursor control and 'less important' keys.)TacticalCoder wrote:What about the lonely key which would be under the palm? When I'm not typing I like to "rest" my palm... Wouldn't that key trigger?jesse wrote:What I did today:
