BIGass (or whatever they're called now) Enter key, fat space, tiny backspace, and - yep - clicky keys.
They look like some ALPS rip-off, with the 'body' moulded into the case upper. The plunger goes between two leaf springs, and has a coil spring attached that activates a membrane connection:
There's no baseplate, just the two halves of the case. It lacks the feeling of solidity you'd get from something with more - erm - construction. This is probably as cheap as clicky keyboards get.
As for the caps, they look ALPS compatible. What's the legending, do you think?
My camera doesn't do real close-ups so it's difficult to show, but they look somewhere between lasered and printed. The legends are clear but lack overall crispness, are slightly pale, and there are occasional minute spots where it looks like they went over the same bit twice. The QWERTY keys are slightly darker than the rest.
How about underneath?
Right. So they have two-colour caps, the definition is good but the legends are pale. There's some roughness to the legending but without a good glass I can't quite tell if that's just the texture of the caps or infill. They don't look like doubleshots, but it seems odd they'd have the darker grey underside if not.
Anyway, a couple more pics for the heck of it (that logo is really heavily textured):
They're not great to type on, but I've used much worse. Action is light and a bit loose.
If anybody's interested I can try to take some better pics of various parts. Note how my photographs illustrate how not to take good photographs...
