CM Storm Quick Fire Rapid US Layout in germany
cmm
I had been using my trusty old G80-3000LPMDE-0 for years but really want a tenkeyless keyboard with similar keys and ideally switches that are quieter. After looking around I found CM Storm Quick Fire Rapid tenkeyless with PS/2 and USB that's available with Brown or Black switches. I couldn't find a US layout version to order in Germany.
I don't know which switches are built into my old G80 but I believe Brown or Black should be similar and quieter. Does anyone know where to order a US layout Quick Fire Rapid with brown or black switches in Germany? Ideally I'd like an unbranded version without all the colorful logos. Is the board real PS/2 and would it work in a PS/2 port? It comes with an adapter and after failing to find a USB adapter for my old G80 that would make it run at a USB port I'm careful to speculate.
Any help is appreciated as I'd like to get rid of the current non-mechanical USB Cherry board asap. Having PS/2 and USB is important because I will use the keyboard with PS/2 with a new pc.
- scottc
You've mentioned a few things in your post that I'll address separately:
You can almost definitely find someone selling a QFR or other TKL board in the Marketplace. Also, if you want to go even lighter than black switches, I know that QWERTim is selling a Filco TKL board with MX Red switches (which feel similar to MX black but with much lower actuation force). Link here: http://deskthority.net/marketplace-f11/ ... %20sellingcmm wrote:I had been using my old trust G80-3000LPMDE-0 for years but really want a tenkeyless keyboard with similar keys and ideally switches that are quieter. After looking around I found CM Storm Quick Fire Rapid tenkeyless with PS/2 and USB that's available with Brown or Black switches. I couldn't find a US layout version to order in Germany.
You can find out by just popping off one of your keycaps. The switch will be coloured brown or black.cmm wrote:I don't know which switches are built into my old G80 but I believe Brown or Black should be similar and quieter.
I'm not sure about this, but your problem was likely that you were using a cheap, passive PS2 -> USB converter. You can get an active PS2 -> USB adapters cheaply on the likes of eBay and Amazon.cmm wrote:Is the board real PS/2 and would it work in a PS/2 port? It comes with an adapter and after failing to find a USB adapter for my old G80 that would make it run at a USB port I'm careful to speculate.
- CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
Amazon.com fast and not expensive
cmm
Are you suggesting I should pm QWERTim? His website and the thread over there doesn't list anything fitting does it?scottc wrote:You can almost definitely find someone selling a QFR or other TKL board in the Marketplace. Also, if you want to go even lighter than black switches, I know that QWERTim is selling a Filco TKL board with MX Red switches (which feel similar to MX black but with much lower actuation force). Link here: http://deskthority.net/marketplace-f11/ ... %20selling
Ducky Shine looks nice but do they also exist without LEDs?
Need to find something to get them off. Plain fingers don't work and I don't want to scratch or damage with metal tools. No info on cherry's website about the switches in that keyboard but couldn't it be those white ones which are not produced anymore?scottc wrote:You can find out by just popping off one of your keycaps. The switch will be coloured brown or black.
Good idea.scottc wrote:I'm not sure about this, but your problem was likely that you were using a cheap, passive PS2 -> USB converter. You can get an active PS2 -> USB adapters cheaply on the likes of eBay and Amazon.
- scottc
I probably should have been more specific. The MX Red switches in the Filco keyboard that he lists are linear, like MX black (so no feedback until the key bottoms out) and with the same amount of actuation force of MX brown. So they are a linear version of MX brown, which seems like it would suit you.cmm wrote:Are you suggesting I should pm QWERTim? His website and the thread over there doesn't list anything fitting does it?
You can get dedicated keycap pullers online. I have one of these from WASD and it works very well. Anything that looks the same should do the job fine. Beware of the completely plastic ones, because I've heard rumours that they can damage your caps (but I'm not sure how true that is, no first-hand experience with this). Before I had a keycap puller I sometimes used a butter knife which worked fine.cmm wrote:Need to find something to get them off. Plain fingers don't work and I don't want to scratch or damage with metal tools. No info on cherry's website about the switches in that keyboard but couldn't it be those white ones which are not produced anymore?
From some Googling and threads on this forum, it seems like your keyboard probably has MX blacks.
- CeeSA
- Main mouse: MM711
Shure, otherwise it would be senseless to recommend it to you....cmm wrote:Shipping from US to DE?CeeSA wrote:Amazon.com fast and not expensive
http://www.amazon.com/gp/product/B0068I ... UTF8&psc=1
I got one in 2013 for $94 - import tax in germany and shipping all included.
cmm
Reds are quieter blacks?scottc wrote:I probably should have been more specific. The MX Red switches in the Filco keyboard that he lists are linear, like MX black (so no feedback until the key bottoms out) and with the same amount of actuation force of MX brown. So they are a linear version of MX brown, which seems like it would suit you.
Browns are tactile blacks?
cmm
In the thread at http://deskthority.net/try-before-you-b ... ml#wrapper there's this comment:
Is there a reliability problem with mx reds?matt3o wrote:really... for a compact wireless keyboard I would also take MX Red (the hell switch!)... who cares I would replace them later
- scottc
No, reds are like blacks with less force required to activate the switch (ie it feels lighter, like a brown feels lighter than a black). Browns aren't tactile blacks, they're more like tactile reds. Check out the Cherry MX article on the wiki for more information.
And no, I think that's just because matt3o doesn't like MX reds. I don't know of any reliability problems.
- Daniel
- Main keyboard: Various
- DT Pro Member: 0028
If you like red switches there's also the possibility of buying a RMA one from here:
http://www.ebay.de/itm/380850121115
My own experience with them is good (bought a MX Black Quickfire Rapid there, which was new):
http://deskthority.net/marketplace-f11/ ... t6100.html
ne0phyte as well: http://deskthority.net/marketplace-f11/ ... t6215.html
If you want to make the keyboard more quiet, there's also the possibility to use O-Rings, which should reduce the sound of bottoming out.
cmm
I don't know if I like them maybe I can find a keyboard at a local electronics retailer to try the switches and get a feel.Daniel wrote:If you like red switches there's also the possibility of buying a RMA one from here:
thanks gonna check out the linksDaniel wrote:My own experience with them is good (bought a MX Black Quickfire Rapid there, which was new):
Isn't that a big change in how the keys feel?Daniel wrote:If you want to make the keyboard more quiet, there's also the possibility to use O-Rings, which should reduce the sound of bottoming out.
cmm
Are there only RMA'd boards on offer on ebay? Is there a reason for not offering new and unopened boards? Just surprised that's allDaniel wrote:If you like red switches there's also the possibility of buying a RMA one from here:
imbattable
- Main keyboard: Some Cheap Aukey MX blue
- Main mouse: Logitech G305
- Favorite switch: Topre
http://www.ebay.de/itm/CM-Storm-QuickFi ... 20e04e6992
just found this in ebay, might be interesting for you!
- Bramster
- Cooler Master Employee
- Main keyboard: CM NovaTouch TKL + Custom DSA Granite
- Main mouse: CM MM531
- Favorite switch: too many :D
Normally our goal is to sell the local layout for local countries. For your case that would mean a German layout for Germany. If you are interested in a US layout you possibly have to look into buying it from other regions. In Holland we sell US/UI layouts.. Possibly you can order from a Dutch site like possibly this one I found:cmm wrote:I had been using my trusty old G80-3000LPMDE-0 for years but really want a tenkeyless keyboard with similar keys and ideally switches that are quieter. After looking around I found CM Storm Quick Fire Rapid tenkeyless with PS/2 and USB that's available with Brown or Black switches. I couldn't find a US layout version to order in Germany.
http://gamepc.nl/game-accessoires/game- ... fire-rapid?
imbattable
Actually, where did you find a CM Storm Quick Fire Rapid with brown switches and german layout (as it sounds in your OP)? I would be very much interested in getting my hands on one of them.
- Bramster
imbattable wrote:Actually, where did you find a CM Storm Quick Fire Rapid with brown switches and german layout (as it sounds in your OP)? I would be very much interested in getting my hands on one of them.
Our USA store has it listed as well: http://www.cmstore-usa.com/cm-storm-qui ... -keyboard/
However shipping might not be the cheapest... In EU we did focus mostly on black switches but in EU we almost have no more rapids available in general regardless of switch..
imbattable
I noticed that with a very sad face. I don't like the black switches very much and thus was "forced" to buy from your competitionCM Bram wrote:imbattable wrote:Actually, where did you find a CM Storm Quick Fire Rapid with brown switches and german layout (as it sounds in your OP)? I would be very much interested in getting my hands on one of them.
mSSM
- Main keyboard: HHKB Pro2, CM QFS MX Green, SSK, ErgoDox (MX Blue)
- Main mouse: CST L-Trac X, Logitech MX518,
- Favorite switch: Buckling spring, MX Green
Any chance to ever get a Quickfire Stealth tenkeyless with MX Greens in Europe?CM Bram wrote:imbattable wrote:Actually, where did you find a CM Storm Quick Fire Rapid with brown switches and german layout (as it sounds in your OP)? I would be very much interested in getting my hands on one of them.
- CeeSA
- Main mouse: MM711
This is a point on which I have always wondered.CM Bram wrote:... In EU we did focus mostly on black switches ...
- rindorbrot
- DT Pro Member: 0029
AFAIK there was some trouble with Filco having the exclusive rights to use side-printed caps in Europe, so I guess it is unlikely...mSSM wrote:Any chance to ever get a Quickfire Stealth tenkeyless with MX Greens in Europe?
- Bramster
mSSM wrote: Any chance to ever get a Quickfire Stealth tenkeyless with MX Greens in Europe?
Jep indeed, we cannot carry in Europe our Stealth keyboard models because they are indeed under patent laws. However we do have the TK Stealth model in Europe.. Because of its unique form factor it is not under this patent issuesrindorbrot wrote:AFAIK there was some trouble with Filco having the exclusive rights to use side-printed caps in Europe, so I guess it is unlikely...mSSM wrote:Any chance to ever get a Quickfire Stealth tenkeyless with MX Greens in Europe?
cmm
So a Stealth board ordered from Amazon USA won't pass the EU customs? Why is it available on local Ebay?CM Bram wrote:Jep indeed, we cannot carry in Europe our Stealth keyboard models because they are indeed under patent laws. However we do have the TK Stealth model in Europe.. Because of its unique form factor it is not under this patent issues![]()
cmm
Been looking at the UK layout rapid board and maybe there's extra labels printed but the the physical keys (return key) look the same. Isn't that right? Is the photo on Amazon wrong http://ecx.images-amazon.com/images/I/41LhDupOx4L.jpgMuirium wrote:ANSI vs. ISO is a pretty real difference.
Nope. ISO and ANSI have different keys, not just labels.
http://deskthority.net/wiki/ANSI
I type on both routinely, and prefer ANSI anyway, but it is noticeable.
cmm
If I believe that site, then Dutch shops carry ANSI keyboards (http://gamepc.nl/game-accessoires/game- ... fire-rapid). ISO has a different return key and the slash key above it and a large left shift and not the <>| key to the right of it.
