working on it again.
Edit:
(Edit: Original thread on GH)
Stick prototype:
The screw will be countersunk in the end.
The stick is made from stainless steel. It is so thin that it will fit through the gaps of the keycaps with hopefully no modification to the keycaps necessary. Not a joystick, it almost doesn't move.
I was never happy with the cat tongue caps as they get dirty fast and the sand wears off. The rubber ones I have are kind of slippery. This one here presses a bit into the skin which provides the friction for horizontal pressure. I'll do another shape, slightly wider, during the next days.
Damned ZIF cables, 0.5mm pitch:
