Telex Keyboard?
- Hypersphere
- Main mouse: Logitech G403
- DT Pro Member: 0038
There is an interesting keyboard posted on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... Track=true
It is a Telex205232-002 952455-002. Does anyone here know what type of switches this uses and if it would require a different controller to function with a modern computer?
5 pin DIN, so hopefully XT or AT:
AT is the same protocol as PS/2, so a simple adapter does the trick. XT is not so easy. But both of them are fully supported by Soarer's Convter, of course!
As for the switches, interesting:
Nothing I recognise. Could be pretty cool.
- Hypersphere
Might it be a Hall effect switch by any chance?
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
Smells like rubber dome.
- webwit
- Wild Duck
It looks familiar, like something I tossed out. Maybe not. Closest I could find was this Compaq rubber dome:
Oh wait, here we go:
http://webwit.nl/input/ergonomic/ergologic/
- webwit
- Wild Duck
This is one of the first ergonomic keyboards of the nineties. NIB. Unfortunately rubber dome.
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
Those are not even listed under [wiki]Switch recognition[/wiki]!
[wiki]Key Tronic foam and foil[/wiki]
I thought everyone knew those …
(Not the Compaq though, though Key Tronic did make foam and foil keyboards for Compaq in the past.)
- webwit
- Wild Duck
I stand corrected. Mostly I remember it feels like shit.
Foam and foil: feels as bad as it sounds? Or were there ever good ones?
I've surely heard of it, and probably even played with a few, but failed the ID test. Bugger…
- sixty
- Gasbag Guru
- Main keyboard: DKSaver
- Favorite switch: Cherry MX Black
- DT Pro Member: 0060
When they were new they might have been decent for a while. All the Keytonic foam and foils I tried have always been awful. Sandy's legendary quote "typing on wet newspaper" is pretty fitting to describe them. The problem is that the foam does not age well at all. So when you have an already mediocre system and add 30 years of the foam rotting away to it... yeah.Muirium wrote:Foam and foil: feels as bad as it sounds? Or were there ever good ones?
Time can be cruel. Speaking of foam: did Model Fs feel different when new, or younger at any rate? My Kishsaver's foam is so flaky I daren't pull apart the plates to replace a bent spring.
- Hypersphere
If only people had had the foresight to store their keyboards under dry Argon, these things wouldn't happen!Muirium wrote:Time can be cruel. Speaking of foam: did Model Fs feel different when new, or younger at any rate? My Kishsaver's foam is so flaky I daren't pull apart the plates to replace a bent spring.
- Daniel Beardsmore
What model is that?webwit wrote:It looks familiar, like something I tossed out. Maybe not. Closest I could find was this Compaq rubber dome:
Clearly we have a point of confusion where someone might mistake that for being foam and foil. Not that I imagine it would be for the worse, but still.
- dorkvader
- Main keyboard: Unicomp
- Main mouse: CST 1550
You have to be careful with these. Alphameric used the same keycap mount (or slider) for their keyboards, but they are entirely different underneath.Daniel Beardsmore wrote:Those are not even listed under [wiki]Switch recognition[/wiki]!
http://www.ebay.com/itm/111309448784
- DT Pro Member: 0011
Interesting... Added to the Wiki.dorkvader wrote:You have to be careful with these. Alphameric used the same keycap mount (or slider) for their keyboards, but they are entirely different underneath.
- Daniel Beardsmore
Key Tronic foam and foil is a "semi-discrete" switch. That Alphameric board has a moulded slider guide plate, just like that Compaq. That's a good starting point.dorkvader wrote:You have to be careful with these. Alphameric used the same keycap mount (or slider) for their keyboards, but they are entirely different underneath.Daniel Beardsmore wrote:Those are not even listed under [wiki]Switch recognition[/wiki]!
Still, that's what [wiki]Switch recognition[/wiki] is for, once enough switches get added to it! Obviously I can't add Alphameric right now.
- webwit
- Wild Duck
One of the Compaq Enhanced III variants.Daniel Beardsmore wrote:What model is that?webwit wrote:It looks familiar, like something I tossed out. Maybe not. Closest I could find was this Compaq rubber dome:
Btw, my Racal-Norsk KPS-10 Lisp Prototype Keyboard also has the Key Tronic foam and foil switches, or something similar (there are some visual differences). Info about this keyboard here:
http://www.kbdmania.net/xe/photo/1525710
Pictures here:
http://webwit.nl/input/kps/
- Daniel Beardsmore
I was hoping for something a little less vague.webwit wrote: One of the Compaq Enhanced III variants.
Still, I did find this:
http://deskthority.net/photos-videos-f8 ... t3862.html
Lots of very detailed disassembly shots. That keyboard has since been added to the wiki, but with exterior shots only.
As for the visual differences in the Racal-Norsk, there were lots of design changes to those foam and foil switches.
