http://deskthority.net/wiki/File:Cherry ... ounted.jpg
The above image is supposed to depict the difference between plate-mounted and pcb-mounted Cherry MX switches, and indeed they do.
They unfortunately also differ in that the pcb-mounted example also has a jumper wire installed which really isn't relevant and might cause confusion.
[Suggestion] Change a particular image to clearify
- damorgue
- Main mouse: MX500
- Favorite switch: BS, MX Green and MX Clear
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
The plate in the top-left image looks more like the switch is floating in the clouds :)
- DT Pro Member: 0011
That is correct. I forgot to remove the wire after I had desoldered it.damorgue wrote:They unfortunately also differ in that the pcb-mounted example also has a jumper wire installed which really isn't relevant and might cause confusion.
