The case will consist of 4 layers in the following order:
- a top wood layer -
- a stainless steel grade 304 frame -
- a bottom wood layer -
- a wood angled base -
Tentative choice of wood is Indian Rosewood but I am also trying to source some more Ebony wood.
An optional plate would be required should the plate be used as a Phantom plate. Plate will be cut from a 1.5mm stainless steel sheet and they will cost around $30-40.
This plate, however, is not required if the case is to be used as a Filco case.
Plate design was referenced from the Phantom files collated by MOZ. Thank you, Moz.
And my sincerest thanks to bpiphany, jdcarpe, WhiteFireDragon for permitting me to use their plate designs
Below are some photos of several prototypes I've made so far:
Prices are in USD and exclude shipping/Paypal fees. Case will be shipped from Indonesia.
Please refer to this drawing to get a rough picture on how each feet option will look like.
Thank you in advance
