"Specs":
MX Clears, except Esc and Enter which are MX Green, and right alt that's MX White because I suck at counting.
Sprit's 75% layout from the geekhack groupbuy.
Mahogany wooden case.
Pictures:
Popping in the switches. I decided on PCB mount due to the costs.
Testing the layout. I'd like to have the keycaps as "set-friendly" as possible, but I ended up with the unorthodox 1.75u right shift because I wanted the arrow-cluster.
Soldering. This went quickerthan expected, helps to have a friend that has access to a proper iron (heats up from 200 to 400C in less than two seconds).
First two rows soldered.
Soldering complete.
Checking the angle on the bottom plate of the case. Think this might be birch. My dad the carpenter helped me with this part.
Glued on the 4 edges, these are the parts that will show and are in mahogany that we found some leftover stubs of.
After the edge has been cut to the same angle as the bottom plate + some sanding.
All riser screws in place. These are just normal motherboard riser screws.
Zomg! It lines up!
Sorry for the blur. It feels a bit high, so a few mm is gonna be sanded of the bottom.
The finish after two strokes of lacquer.
Still feels a bit high. But I'll know after a couple of weeks of use if it's too high.
The edge to cap distance seems very good.
Done! Kinda. Still lacks stabilizers in this picture, but that doesn't show.
Bonus-picture! With Nuka Cola spacebar that I won from Ducky Nordic over at his marketplace thread.
A few months later picture, now with the 1976 key caps:
