does anyone have experience dismantling a futaba switch in a not destructive way?
there are 4 rivets on the top of the switch, it seems you need to remove those, but can the switch be closed back?
thanks!
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
I would assume that you could clamp and glue it afterwards. From the very few pictures I've seen, I don't think there's anything else that holds it together but those rivets.
The mini Mitsumis are worse: I can't figure out how to get one apart without tearing whole pieces off it, which is what I had to do. The Futabas look like you could carefully drill or cut the rivets and then replace the top with lots of glue, enough to withstand the spring force.
- matt3o
- -[°_°]-
thanks, that's what I thought. I could epoxy glue them back, even though it seems a little risky, if glue slips inside, bye-bye futaba
- matt3o
- -[°_°]-
a lot indeed!
- Daniel Beardsmore
I hope you don't have a large supply of Futaba keyboards that you're keeping to yourself ;-)
- matt3o
- -[°_°]-
LOL. just one (but with Cyrillic legends)
and in very bad shape, it will need a lot of love to make it shine back to lost splendor. I wanted to convert it into a 60%. I don't know...
I should get it in a week or so.
Ah, "not yet". Show us the case and we will judge you for your wisdom or your rashness for wanting to chop it into shape!
I have the same desire to mod an NMB RT-102 that I got in a recent trade, as it feels superb and has a fairly yellowed case anyway. Plus the controller is not behind the numpad, so I could TKL it in theory. But it's too nice for me to really consider taking to a saw…
