Macro/Gaming Keyboard
- beltet
- Main keyboard: Custom NerD60
- Main mouse: Saitek cyborg R.A.T 7
- Favorite switch: Ergo MX Clear
Hey everyone!
I'm thinking of building a specific Gaming/Macro keyboard and want your input, otherwise it ain't going to happend.
I love to use 60% on regular basis, but when I'm gaming I sometimes need the F row seperate or MANY macros to do what I want. So the 60% ain't enough.
First of I'm thinking of getting one of these:
http://www.ebay.com/itm/130541363513?_t ... EBIDX%3AIT
I think I have read that it can take cherry MX switches?(Think I saw that Mirium posted it somewhere, and on geekhack aswell).
And does the keycaps fit on Cherry MX? Because I will print my own "legends" and need relegendable keycaps.
And anyone have an idea for a case?
Second is the pro micro(Teensy copy). The matrix would be 5x5 and then I need 10 connections to the pro micro, right?
The third is what firmware would be the most suitable for macros? I have used Soarers converter and the macro function is what I remembered in some sort of beta. Would like to test another even if I really like soarers otherwise.
Thoughts?
Thoughts?
- beltet
Got the plate and switches today (2014-09-28).
The switches are not that good. And the caps are not MX compatible
But the plate is good, fits MX very well and quite sturdy. Guesses its aluminum. Because you can bend it with handforce.
And made primitive feets from motherboard standoffs.
Will start testing as soon I get my diodes in the mail.
Pictures:
Got the diodes and started working on the matrix:
Done with matrix, the first soldering are real bad... But It became better after I started to use solid wires that you can bend(yellow, blue, green) and some trail and error:
Pictures:
- vvp
- Main keyboard: Katy/K84CS
- Favorite switch: Cherry MX
Cherry MX are often used because there are many sources of keycaps for them. Even relegendable.
An AxB matrix will support A*B keys and needs A+B GPIO ports on your controller. Pro Micro (as well as many others) should do for your rather small 5x5 matrix.
Here is a firmware with macro and remap support too:
https://github.com/chrisandreae/keyboard-firmware
For a standard keyboard use, on the fly remap looks even more important than macros.
We use it for a different project. Though besides remap/macros we need also support for fibers. It is the only option (I know of) with these two featues.
- beltet
I have ordered the plate and switches and see if the caps and plate function with Cherry MX.
Do the firmware support ATmega32u4?vvp wrote: Here is a firmware with macro and remap support too:
- chzel
- Main keyboard: Phantom
- Favorite switch: Beamspring, BS, Vintage Blacks.
- DT Pro Member: 0086
Beltet, if you check the switches he has on sale (clicky) he specifies them as using a 14x14mm hole to mount, so the switches will 99% fit! Hopefully the relegendable caps will fit too!
And from a quick glance, the firmware vvp linked to does support 32u4 (aka Teensy 2.0, aka Pro Micro).
- beltet
Thx for all the info! Will start working in it as soon it comes here.chzel wrote: Beltet, if you check the switches he has on sale (clicky) he specifies them as using a 14x14mm hole to mount, so the switches will 99% fit! Hopefully the relegendable caps will fit too!
Thx!
- beltet
The cross slot seems to be the same size, cherry caps fits well on the switches. But the thickness is to wide and length are to short on the keycap stems. So the keycaps cant "get hold of" the stem on the switches before it make contact with the switches housing.
Please tell me if I was very confusing. May using the wrong terminology.
EDIT: For the curious, those blue switches are linear. And the caps are spherical.
- beltet
- vvp
Maybe the key caps can be fixed with a small grinder/drill.
Other option (if you want Cherry MX) is to get relegable keycaps from e.g. from the link in this message:
http://geekhack.org/index.php?topic=480 ... msg1026623
- beltet
I thought about that but if I was supposed to grind it enough to fit the housing hole it would be to much...vvp wrote:Maybe the key caps can be fixed with a small grinder/drill.
The stems cross is to big and I would destroy the stem.
Thanks for the tip on that POS keycaps. Quite cheap per unit. I've seen that before but didn't know it was cherry compatible!
Will contact and see if there is a possibility if they can ship together with the Granite Round 2 extra kit.
- DanielT
- Un petit village gaulois d'Armorique…
- Main keyboard: Various custom 60%'s/HHKB
- Main mouse: MS Optical Mouse 200
- Favorite switch: Topre/Linear MX
They can, you have so sweet talk Melissa to invoice you for what you want, but it can be done for surebeltet wrote:I thought about that but if I was supposed to grind it enough to fit the housing hole it would be to much...vvp wrote:Maybe the key caps can be fixed with a small grinder/drill.
- beltet
I have problems with hotkeys in my favorite game company of heroes 2. The hotkeys are almost always one specific key instead of like ability 1 for all units is key "q".cookie wrote:For what games you actually need macros?
I am asking out of curiosity because I game a lot and never felt the need for macro keys.
And units have their own letter as well. So I will map units and the most used abilities on that keyboard.
And this is my first "from the ground up" keyboard and I want to learn about matrixes, controllers and software. And I thought this build would be easy to do and learn.
And just for the fun of it and see if it works
