It's meant to be a travel board (I have an infinity ergodox at home) so I used cherry clear switches to be polite. everything is hand wired into a teensy 2.0. I'm still working on the firmware but it's functional enough right now to type out this post.
I'm particularly proud of this usb port. On the normal atreus you just run the usb cable from the teensy through the case to the computer. Amphenol makes all sorts of heavy duty industrial stuff, including an all-metal micro usb port. It gives me no small amount of satisfaction to know that any stress on the cable will be transmitted by bolts to the case rather than by solder joints to a pcb.
My initial vision had everything precisely fitting together and sanded down to a uniform gleaming finish. I could tell that wasn't in the cards so I embraced the rough-hewn look and didn't use anything finer than a grinding disk for finishing. It has some rough spots but its pretty smooth to the touch. I coated it with wax designed for museum armor collections to prevent rust.
