What alternatives are there to convert Model M to QMK?
Is there any custom pcbs or is my only option to wire it up myself?
Convert Model M to QMK?
- Main keyboard: Novatouch
- Main mouse: Razer Mamba Wireless
This seams to work, I just thought there might be a more "clean" solution?
https://github.com/qmk/qmk_firmware/tre ... /modelm101
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
Google around or search deskthority.net for "phosphorglow colossus". It was running TMK. Even if you can't get NKRO because of the membranes you can still get reduced power consumption and macros. Good luck.
- AlbertoGP
Not QMK but programmable: user mind_prepared makes and sells replacement controller boards with USB and optional BlueTooth: viewtopic.php?t=17388
